Zum Hauptinhalt wechseln
JBL Flip 4 tragbarer Lautsprecher. IPX7-wasserdichter Bluetooth-Lautsprecher, der mit dem CES Innovation Award 2017 ausgezeichnet wurde.
83 Fragen Alle anzeigen
Why is the sound of the JBL Flip 4 turning off or not working at all
I have the JBL Flip 4 for 14 months, it worked fine. However now with the unit turned on, there was no sound or the sound disappeared after a short time  (seconds to minutes). All buttons and connections worked. The problem was observed with the speaker connected by cable to the laptop or via Bluetooth to the smartphone. Resetting the speaker (pressing simultaneously play and plus buttons) did not help.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If your JBL Flip 4 speaker refuses to connect to another device through Bluetooth, see the JBL Flip 4 Won’t Connect Through Bluetooth problem page for possible causes and solutions.
I searched for many hours on the web and could not find any answer. Finally, by trying various combinations I found that with the JBL FLIP 4  turned on and by pressing simultaneously the Bluetooth discovery mode button (left) and the volume down button the problem was solved.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
The next day I found the same problem again. So, this was not the solution, just a co-incidence. The sound still cuts off in an unpredictable manner. Looks like a loose contact loose contact somewhere.
von
Mine is having the same issue.
von
Antwort hinzufügen
Wolfgang Siess wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 20
Insgesamt: 1,361
