Zum Hauptinhalt wechseln
The Sony Ericsson Xperia X10 was the first Sony Ericsson smartphone to utilize the Android operating system.
How do You fix or replace the Charging Port
I have a Sony Ericsson Xperia X10A and the past week i have noticed a loose charging port. Today the phone will not charge at all. I have changed batteries and chargers, but still not charging. I did some research online and have found that these phone are known for loose charging ports. I have order a new charging port but it doesn't have intrustions with it. I love my phone and it's not even a year old, so i just want to fix it not replace it. Can you help me?
Thanks
Tracy
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Tracy Richards, just make sure that if your phone is still covered under warranty, use it. Don't tear it apart unless you are not covered...
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Tracy Richards, the service manual is available right here. It will show you how to replace things that are replaceable. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 1
19 Kommentare:
Thank you. And no my phone isn't under warranty. Thank you for your help.
von
Thank you for accepting my answer. I hope things will work out for your phone.
von
hey do you mined sending it to me pls at grownupgear@yahoo.com pls
von
Sorry, I don't do emails because of size etc. you should download it here :-) good luck.
von
Hi oldturkey0
Can you set the sharing so i can view the manual
Thanks in advance
J
von
14 weitere Kommentare anzeigen
Antwort hinzufügen
Tracy Richards wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 36
Insgesamt: 11,726
