The Bosch GBA Battery is a basic battery that comes as a pair in common cordless drill sets made by Bosch, a German multinational engineering and technology company. The GBA battery can be identified by model number 2607336800.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
If the resistors are already there, either read their markings to determine their resistance value or disconnect (unsolder?) one end of the resistor from the circuit board and use an Ohmmeter to measure the resistance between the resistor legs
I have Bosch GBA Battery 10.8V (3 cells). When i was open battery pack one more room for 3.7v cell (18650). I soldered one cell, but charger (10.8-18v) can't determine upgraded battery pack, because internal 2 resistors different for 10.8v pack and 14.4v battery pack i think. i need value of resistors of 14.4v battery pack
Hi @odbileg ,
More information is required.
Which resistors?
What are you trying to do?
von jayeff
Hi @Jayeff, Thank you for reply.
von Odbileg
