Zum Hauptinhalt wechseln
Das Samsung Galaxy Tab E 9.6 wurde im Juni 2015 angekündigt und im Juli 2015 veröffentlicht.
Tablet touch stops responding suddenly.
Hello.
My tablet Gakaxy Tab E SM T561 works fine while I'm using it. After 6 to 7 hours of use or within 2 to 3 days it will suddenly stop responding to my touch. Turning it on or off doesn't solve the problem. The only thing that seems to work is that if I leave it untouched for a couple of days it would start working normally again and go back to same issue again and the cycle repeats itself. I've tried soft and hard resets, rom flashing, sd card removing, sim removing, slapping, hitting and spanking! Nothing works! I took it to the shop and he said there was something wrong wih my touch IC but that didn't work as well.
I've owned this Samsung Galaxy Tab E 9.6 Wifi + Cellular for 4 years now and I dont know how to fix this issue. Its driving me nuts. Thankyou.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi,
When you said “….took it to the shop and he said there was something wrong wih my touch IC but that didn't work as well.”, does that mean that the touch IC was replaced?
As a DIY repair most probably the only thing left to try is to replace the touchscreen and check if the problem still occurs.
If it doesn’t then the problem was in the touchscreen. If it does then the problem is on the systemboard.
You have to start somewhere and see if you can narrow it down to where the problem is and this would be the first step.
Here’s a link to the ifixit Samsung Galaxy Tab E 9.6 Wi-Fi Touchscreen ersetzen guide.
Replacement touchscreens are available online. Just search for Galaxy SM-T561 touchscreen to get results for suppliers
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
The touch IC wasnt replaced.
I'm aware it's probably the touch or digitizer or both. I just want to know if it's only the digitizer because I've searched online and they say if you heat the borders or ‘slap the digitizer back into place'. But I dont wanna try this. If you could please tell me a few things u can try before I go to the penultimate option of replacing the touchscreen.
von
@ahmedmarjanzia ,
Touch and digitizer are the same thing. Touchscreen is just the more common name for the digitizer
Like most electronics you have to know where and what the problem is before you can fix it, if you want to have a permanent repair.
I'm old school. I was taught to find out where and what the problem is so that it can be fixed.
I'm sorry that I can't help you on this one, because until you know where the problem lies so that you can then find out why it is occurring, it is only guesswork, but you may be lucky
von
Hi there. I also have Samsung Galaxy tab e t516, I tried a new touch but still not touching. I don't know where is the problem now. Please help.
von
Sorry for my lately answer. I also own a samsung t561 model tablet (tab E 9.6) and it works smooth,I mean,really smooth. Even It can finely run heavy games like Free Fire or PUBG lite type games.What the main problem I face is that my tablet frequently retarts all by itself, without showing any lag or something like that before restarting. The problem started almost 1 year ago, after 2-3 months of buying the tablet, I was enjoying a youtube video and the screen got stuck[It should be mentioned that I always turn on the "show touches option' from the developer option,So I noticed my scrolling touch response on the screen could also be seen when the device was stuck].I followed the restarting method using power button and volume buttons and the tablet restarted.After somedays, the tablet frequently started restarting automatically in every one or two hours.It became almost unusable. So, I used an app called ram cleaner and it slightly decreased the problem but did not remove it.The tablet is still very fast but the problem hasn't gone. I think its the problem of the management of ram or chipset. Again,the tablet didn't get any major software update. It is still running android 4.4.4. Forget about the specs, anyone would say that the tablet should have got a android 7 update for sure just by experiencing its performance. So, I think the problem might be in the sofware or cpu. Like see,many phones are seen to be super laggy, but they do not restart or get stuck. I think something is making the ram or the processor totally stop all the works, it can be a software bug or any motherboard ic failure,but what it is, it's ultimately causing this problem. Samsung should have given at least two years of software update for this tablet, I don't know why they forgot this model. I have seen few people who have solved this problem by downloading higher android version based custom rom.But there is a risk to brick this tablet. So,not everyone can use this method. SAMSUNG shouldn't have done this. if it was a product of apple, we could surely get a soution. @ahmedmarjanzia
Bewertung 0
Antwort hinzufügen
ahmedmarjanzia wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 627
