Zum Hauptinhalt wechseln
Das März 2015 Update bringt jetzt die fünfte Generation der Intel Core i5 und i7 Prozessoren in das Apple 13" MacBook Air, dadurch wird die Leistung und die Akkulaufzeit etwas verbessert.
623 Fragen Alle anzeigen
A1466 MacBook Air 2015 does not power on
Have a Macbook Air here that will not power on anymore. The light on the magsafe connecter comes on when it is plugged in and turns orange but nothing happens when the power switch is pressed.
From what i’m told it first just started to not power on then a few weeks later it would suddenly power on when tried then the owner was afraid to switch it off and left it powered on and it went to sleep after which it never powered on again.
I’ve opened it and disconnected the battery and it still does not power on when the magsafe is plugged in .
I’ve a good few years experience repairing PCBs but the only equipment i have at home is a multimeter. Can anyone point me in the direction of test points or a guide to troubleshooting this? I’m fairly competent with electronics repairs so please go into detail if possible.
Thanks in advance anyone! Any help will be greatly appreciated!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Any sign of liquid damage in this MBA ? Did you remove the logic board and made a visual inspection of the two sides (magnification would help). It takes only a little corrosion on a critical component to kill the board.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I haven't completely removed the logic board yet as i'd like to know a bit more before i go that far but i'm fairly certain there have been no spillages
von
I saw many MBA boards that were very clean, no sign of liquid damages but one component corroded, Hard to know where it comes from but once repaired the MBA was ok.
von
Antwort hinzufügen
Cricky Lyttle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 68
