Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
Ipad 6th Gen won`t charge
I have an iPad 6th Gen. It won’t charge at all. What is wrong? Used original cable to charge.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
Firstly, try another lead. If this doesn’t work, then you have a faulty dock connector or a bad battery. I use an iPad 6th gen, and they only came out on March 27th 2018, so you are lucky enough to still be in your 2 year warranty if you bought it from Apple or an authorised reseller. Contact them about this issue, as this is a hardware issue that they should fix free of charge.
Hope this helps :)
War diese Antwort hilfreich?
Bewertung 3
4 Kommentare:
What if it was broken bc of the user’s fault?
von
If it’s broken by the user then a repair shop will be able to fix it easily
von
Yes to whom it may concern, I have a iPad 6 and it will not charge any longer and I was wondering if I send it to you guys would you
Possible be able the clean it and figure what's going on with it, it seems as though I just got it back in December 25th of 2029. Like I've said in my pass words to you guys it stop working about 4 to 8 weeks ago and it really stinks that something that's this most expensive would have a better warranty with it…. Please let me know if you work on the iPad 6’S and what the average cost may be to get it repaired…..
Thanks Many and Many Blessings
Vince Corter
von
Hi,
I don’t think that iFixit do mail-in repairs, as I think that is who you were addressing. If you only got it December 2019, take it into wherever our purchase it and get them to have a look, as it’s not a year old yet. Let me know if the outcome :)
von
Antwort hinzufügen
Mohammad A Butt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 20
Insgesamt: 5,561
