Zum Hauptinhalt wechseln
iPad Mini mit 7,9 Zoll Display und 16, 32 oder 64 GB Speicherkapazität.
630 Fragen Alle anzeigen
Messed up screen need help
When I woke up this morning my iPad had a light but visible layer of white and white lines it affects things like the app Andy every thin but it is purely a visible problem I don’t know how to fix it and ideas?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi,
Firstly, has the iPad been knocked or dropped? This could have damaged the LCD, or disconnected one of the flex cables. This could happen anyway, even without a drop, but less likely.
The other problem it could be is a motherboard issue, it water has got inside, or the iPad has been opened up and tampered with in the wrong way. If there isn’t a possibility of either of these, then most likely a disconnected cable, which can be fixed simply by opening up the iPad, disconnecting the screen, and reconnecting it.
Please remember to disconnect the battery if you try this as to not fry the backlight!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Absent Kiriko wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 35
