Zum Hauptinhalt wechseln
Starter wont disengage, why
I have replaced the starter on my 2000 chevy cavalier with 2.2L engine 2 times in 3 days, it works great at first but will not disengage, there is nothing wrong with the flywheel, not sure how to fix it or what to check.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I figured out the problem, the person that put the first replacement on had a wire in the wrong spot. Thanks for the help
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Check the spacer in the nose end of the stater. If it is missing the bendix gear will extend to far into the flywheel causing it to hang in the engaged position.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
When I put the starter on it did have the little sleeve but when I took it back off not even a day later it was chewed up
von
Antwort hinzufügen
Jwanna C wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 327
