Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2010 / 3,06 & 3,2 GHz Core i3 oder 3,6 GHz Core i5 Prozessor
342 Fragen Alle anzeigen
Can display data cable make my screen go blank
My intel iMac Pc was not powering so i opened it up remove the power supply and changed the capacitor this solved the problem for a while later same problem occured fixed it again and coupled it back even with the data display cable tucked in properly the system gives sound on power up but nothing to show on display how do i fix this
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
To verify that its the display or a display compontent, plug in an external monitor. If you see something, then its the display, if not, its your logic board or your GPU.
War diese Antwort hilfreich?
Bewertung 3
I did a hard drive upgrade, and at first, my screen was blank, but would show up on my TV, it turns out the cable's lock is VERY sensitive, and you have to plug it in properly, then be careful with the LCD. For some reason, it does not work when I had the torx screws around the LCD in too tight.
Bewertung 0
Antwort hinzufügen
bayoadenuga wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,137
