Zum Hauptinhalt wechseln
Repair and disassembly guides and support for wall oven appliances.
What is the right glue for an oven?
I have an eye level oven, and the door contains three panes of glass. The innermost glass sheet can be unclipped for cleaning. There are two metal clips, glued on with a silicone type adhesive. They have come off, and I need to reattach them.
The clips are not in the oven body, which can get to 450 degrees centigrade (Pyrolytic) but glass is conductive, and I’m sure it gets very hot anyway.
I cannot find a glue rated more than 300 degrees.
Another alternative is an automotive “liquid gasket” product, but I don’t know if that acts as a glue?
Model: VOGUE Pyrolytic Wall Oven
https://www.tradedepot.co.nz/pyrolytic-w...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
This question was migrated from https://meta.ifixit.com/Answers.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@ladytech found this
 searspartsdirect I found an adhesive used for ranges and high temp.
Part #W10841140
Sears sells it for $9.01
I believe it is just a silicone sealant for high temp
Glass on oven door swinging free
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
I’m glad you found it. I’m going to save the # for future reference. Hope you healthy and sheltered at home. Don’t forget to wash your hands.
von
Need glue as well for oven that seals the inner glass not outside
von
Antwort hinzufügen
Michael wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 2,015
