What is this on the motherboard that broke?
There is this “ground pin” look a like, that broke of the motherboard, and I do not know what it is. I tried to solder it, but the bottom of the “pin” just came lose. Will the device function without it, and what part will lose functionality? It connects to the midframe of the galaxy.
Can I connect that “ground pin” directly to the side of the resistor?
In the schematic it says ANT4003, does it connect to the top part of C4047?
Part code 3712-001564 , related to BT/WIFI. How to fix this nightmare?
Ist dies eine gute Frage?
You'd need the solder skills of a super genius to attempt fixing that... Try following the schematic to whatever component that lead goes to (nearby or flipside), then solder a wire to that and connect to the frame
von Jeff
