Zum Hauptinhalt wechseln
Ein Mittelklasse-Smartphone von Samsung aus dem Jahr 2019
117 Fragen Alle anzeigen
Access Broken Screen phone display to enable USB Debugging
The phone is running and is connected to Wifi but USB debugging is not enable.
Is there another to access it. I can access the battery percentage on my Samsung Account (Find my phone).
Will be really grateful if can help. I can also connect a USB mouse to phone through USB-C type dongle.
Thank you very much.
Ashvin
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
@riaztex .... if you cannot utilize the onscreen, and cannot use any other means of viewing, i.e mini usb to hdmi...then im afraid youll have to do it by memory or pull up a video. I say this as it is functioning and you can enter back up mode to save all of your data you want. but youll have to do it in the dark without access to any screen.
von
Sumsung A50 screen change karane baad mai Not changing show
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@ashvinp … to manually enable usb debugging do this:
go to settings/general/about phone/software info/ tap on build number until it prompts for developer mode.
go back to settings/general/ youll have a new menu for developer options/ turn on developer options/ turn on usb debugging.
if youre doing this for root, make sure to enable oem unlock so that you can use adb to access root partitions such as bootloader …yada yada.
as far as viewing your screen if it unviewable, you can try a mini usb to hdmi adapter or something of the sorts to try and navigate. other than that, theres nothing i am aware of without being able to navigate your screen already. good luck
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Ashvin Pandea wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 3,025
