Zum Hauptinhalt wechseln
Die Xbox Spielkonsole der dritten Generation von Microsoft kam am 22. November 2013 auf den Markt;
727 Fragen Alle anzeigen
Can’t connect/sync a controller to my Xbox, or find any WiFi’s
I brought an Xbox off some guy a while back and it worked fine for a while, connected to everything, all of a sudden it wouldn’t find any WiFi when I searched, tried hard reset etc, looked online found nothing, then my controller sync button went too, no flashing on the Xbox when holding or pressing it, the controller just continues to flash and connects to nothing, I’ve been using a wired connection on both WiFi and controller for some time now, and today while gaming my controller disconnected and never connected again, tried 3 different controllers with 3 different wires and none of them connect atall, just connect to the other Xbox, tried all I could find online again, nothing. Any help please? Much appreciated
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
callum.mayers … your wifi card is probably bad if nothing works wireless but works wired. here is a link for the part and instructions to replace it:
Xbox One Wi-Fi Karte austauschen
post back here if any further assitance is needed.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
I’ll check that out but the controllers etc have stopped working wired too
von
id say if none of your connections are working now, wired or otherwise....there is possibly a bad ic for this. schematics are rare to find, but if you find one....link it here and we can take a look at the possible culprit(s). good luck
von
What is the model of your xBox ?
Bewertung 0
2 Kommentare:
I actually don’t really know, I think it’s the original Xbox one that first came out
von
when and if you open up your unit, list the board number and that will help track down what schematic we need.
von
Antwort hinzufügen
callum.mayers wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 37
