Zum Hauptinhalt wechseln
12.1" netbook has an AMD E450 APU running at 1.65 Ghz, Radeon HD 6250 graphics, 1366 x 768 screen resolution, release in April 2011.
Asus 1215B does not charge the battery.
Hi, I have a problem with my Asus. When I plug in the power supply, the battery doesn't charge. The power supply has the correct voltage. I'm attaching the BatteryMon screenshot.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
If it’s an older laptop, most likely the battery will need to be replaced. Batteries are consumable items whether it’s a TV remote or a car battery, it’ll need to get replaced at some point.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
BatteryMon shows a voltage of ~7V to 8V and the battery should be 10.8V. So it's probably due to the battery?
von
Most likely a dead cell then, so yes a bad battery. And voltage is a measurement of charge, not capacity. A bad battery can show gold voltage but as soon as you put a load on it, that voltage can drop.
von
hi
you need to replace laptop battery
Bewertung 0
Antwort hinzufügen
Jan Kowalski wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 510
