Zum Hauptinhalt wechseln
Modell A1418 / Ende 2012 / 2,7 & 2,9 GHz Core i5 oder 3,1 GHz Core i7 Prozessor
212 Fragen Alle anzeigen
No Backlight on iMac. Next Steps?
Hi Everyone! I picked up a 2012 IMac A1418 EMC 2544.
The LCD Panel works, but there is no backlight. I am able to use a flashlight and I can see everything and it functions perfectly. AHT said no issues. The computer also can connect to an external display and everything is perfect. My question is, what are the next steps in diagnosing the issue? From my research, I am pretty sure I will have to replace the logic board. Is there anything I can/should do before doing a full logic board replacement?
Thank you in advance!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Your problem might be repairable! Check the cable is not damaged and then on the back side of your logic board is the backlight power logic, check the fuse link
U9700 - LP8561
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks for taking the time to answer! Once I have the iMac open, I will check the cable and fuse before trying to replace the entire board. Thank you!
von
Antwort hinzufügen
Thomas Shown wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 144
