Zum Hauptinhalt wechseln
Modell A1059 oder A1099 / 20, 40, oder 60 GB Festplatte/berührungsempfindliches Klickrad
Why doesn't it work when unplugged?
It works when plugged into pc. It shows a full charge but doesn't turn on when unplugged. What is wrong? How can I fix it?
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
7 Antworten
Hilfreichste Antwort
Sounds like replacing the battery would solve the problem.
War diese Antwort hilfreich?
Bewertung 3
I had a very similar problem. The charge on my 4th Gen Photo battery would last less than 30 min. before completely depleted. In addition, I would plug in the firewire charger into a wall outlet noting that the date and time would reset to Jan 01, 2000 0000hrs. I did not lose any on my tunes. Thus I only listened to it if I was able to plug in in to an outlet somewhere.
After seeing the replace battery suggestion noted above, I did just that. I disassembled my iPod and discovered that the battery within was bulging from the center --- (I had a similar problem with a cell phone battery that fail to maintain a charge) --- swapped out the batteries, charged it up and have not had a problem since. With the proper tools I had purchased here at iFixit (yes, you need the spudger to remove the old battery), my total repair time was less than one hour.
Bewertung 0
hi, mi I pod got stuck on one song and it will not turn off or change to any tracks, what could be wrong
Bewertung 0
1 Kommentar:
please start a new post- just ask a question :)
von
Have you tried a soft reset first to get back to the startup screen?
Bewertung 0
My iPod will turn on if plugged into the Bose Dock player but will not if held in hand
Bewertung 0
After charging with PC USB it got stuck with eject option. But nothing is happening with My Apple IPOD just showing msg eject before remove.
Please help
Bewertung 0
tell me what i cant do
Bewertung 0
Antwort hinzufügen
cindy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 3,394
