Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
Part of screen not touch responsive after display replacement
Thank you for your guide. I’m almost finished but before closing the screen to the frame I’m testing whether the touch works. But on the unlock screen all numbers but 1, 2 and 3 work. What could cause this problem? I have installed the kapton tape on the replacement screen.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Did you unhook the battery before you took off the screen and reinstalled it? Unhook the battery and disconnect the screen connector and get a magnifying glass and see if the pins were damaged. If they are ok on both connectors than take a qtip with a little alcohol and clean the connectors then brush them off with a soft brush. Reconnect and try it again
War diese Antwort hilfreich?
Bewertung 2
Hey Allan Barr,
Thx for your comment, I also had small part of the touchscreen that did not responded.
Followed your steps and it’s working 100% now.
Thank you for your contribution!
Grtz
Bewertung 0
Antwort hinzufügen
Michel Braamhaar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 24
Insgesamt: 757
