Zum Hauptinhalt wechseln
Repair and disassembly information for the Samsung 55" UHD television with model numbers UN55MU6290xxxx. Released in 2017.
56 Fragen Alle anzeigen
Compatible other main boards for samsung un55mu6290f version CB05
I have a faulty main board of my samsung tv un55mu6290f version CB05 and the board number is bn94-12662z. Unfortunately I couldn’t find a similar board on online with the exact number but there are other boards supported for same model un55mu6290f with different versions. Is the version is a big factor and what are the odds of working those boards in my version?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@dimuthuupe other main board s that support your model “may” work. We do not know what the revisions to your current board are. It could be something as simple as different placement of components but could be as complicated as rerouting tracing etc. I would suggest that you try one that is listed for your TV even so it maybe a different revision. There is always a reason why certain boards are not readily available. It is usually caused by some issues with the board that have led to too many failures. Again, try a different revision of the same board and see what it does.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Dimuthu Wannipurage wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 844
