Since making repair help pages is more of a pain then using WIX on here let me try to help others by answering my own question.
Is your screen frozen and you are already booted up and are at the “desktop” screen (where you can either see all of your alerts or apps) and all you can do is press the power button and that just turns the screen off and on and the volume button(s) works but you cannot activate anything on your screen when you tap on it?
If it was me all I would do is get a paper clip and gently put it into the hole that is right next to the power button far enough inside so it presses the reset button and then remove it and then your table should restart.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
3
1 Kommentar
Dude we push the power button turn it on factory reset and it still power on say dragontouch across the screen in middle and in center at bottom say powered By android and it stays there unles I factory reset or restart. But where I can review logs it’s say block on some idk why
von Derrick Criswell
