Zum Hauptinhalt wechseln
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 Fragen Alle anzeigen
My car will not crank or turn over. She does nothing.
yes I have a 2004 grand am and she was running just fine and then today I got up to go to the store and went to start my car and got nothing. Checked the battery it's good checked the starter its good I have power when I turn on the key but she does nothing as if she was not in park sort of speak but when I took her out of park put in nutural and back in park I got the same results nothing. Please help someone. Id really appreciate it. Thanks. Michele
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Did you try to start it in neutral? You can have multiple problems. You need to start at the stater solenoid and see if you are getting 12 volts while the key is held in the start position. If you have 12 volts it has a bad solenoid or starter. General motors has issues with the starter solenoid sticking especially if it's hot. You can also hold it in the start position and whack the starter with a hammer. If it starts put in a new starter. If you don't have 12 volts to the solenoid check the neutral switch and verify that you have power going to the neutral switch while in the start position. If you have power going to the neutral switch but not coming out then it's the neutral switch. You also need to verify that the starting relay is good. Then you need to check the starter switch which is either part of the key tumbler or it can also be on the bottom of the steering column. You basically need to see if you have power coming from the switch, through the neutral switch, and the starter relay and to the starter solenoid. My best quess is the starter bushings are worn and when you try to start it especially while it hot. The armature will fall next to the windings and it can't create a magnetic field to turn the starter motor. So if you hold the key tumbler in the start position and someone taps the starter hard it will knock the armature off of the windings and the magnetic field will hold it in place and it will start. But most likely it won't happen again. I would have a mechanic diagnose the problem. If you take the starter into autozone or one of the parts stores and have them test the starter it will most likely test ok but won't work on the car while it's hot. It gets really hot in that area. I hope this helps
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I have the same problem with mine I had to key bypass code turn the key on for 10 minutes that shut off wait 5 seconds then started
von
Antwort hinzufügen
Michele Becker wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 33
Insgesamt: 2,857
