Zum Hauptinhalt wechseln
Das ist die Variante ausschließlich mit Wi-Fi der fünften Generation des iPad, erschienen im März 2017. Erhältlich mit 32 und 128 GB Speicher, einem 9,7" Retina Display und einem 64 Bit A9 Prozessor.
iPad not turning on and heat on charging
iPad worked fine, then at the morning it didn’t turn on. At night it was about 50%+ of charge. I tried all solutions I found: charge it for hours, press Lock + Home in different variations, connect to Mac (with different combinations of buttons) – nothing helped.
The only sign it shows – heating on charge. Called to service, they said that iPads can’t be repaired and replacing unit will cost me $300. Didn’t plan to buy new iPad now, is there any more solutions to try?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
There is a possibility of bad battery. I would try a new battery. Did you use an aftermarket charging cable? If you use a charging cable that was not an Apple cable or MFI Certified cable can cause the tristar ic to be damaged and it can cause it to not charge and no longer be able to transfer data. The aftermarket charging cables can cause voltage spikes that damage the tristar ic.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thank you for the answer. No, I use original Apple cables. The only specificity of the iPad use was that it very often used until turning off due to low battery. It may cause the damage, I guess. How much repair would cost?
von
If you have someone do it around 100 dollars.
von
Antwort hinzufügen
Guest User wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 373
