Zum Hauptinhalt wechseln
Dieses Gerät hat mehr Features als ein einfacher Controller, wie zum Beispiel abnehmbare Thumbsticks und einen Steuerkranz aus Metall. Der Controller wurde primär für eine Nutzung mit einer Konsole konzipiert, er kann aber auch am PC genutzt werden.
59 Fragen Alle anzeigen
Elite Controller Series 2 (Not 1)  Battery Replacement
Microsoft’s latest ‘Elite’ Controller 2 (04/11/2019 UK release) has a built-in battery, is there a reliable teardown, where I can safely access the controller internals to replace the battery for future reference?
(I would’ve selected the correct device, however Elite 1 was the only option)
Thanks in advance!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
so basically you take of the two rear hand grips, and unscrew the four screws which are torx T9 screwdriver bits, then you pull of the front casing then take the internals out of the rear casing, disconnect the battery from the port on the mother board, then you plug in your new battery put your internals back in the rear cover, put the front cover on screw it back together and put the hand grips back on and hey presto new battery this wont take any longer then 10 minutes to do and you’re welcome
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
where can you get a replacement battery ?
von
Thanks for the replying to this
von
Hilfreichste Antwort
Hello there, yes you can replace the battery.
There is a good teardown video here which I used to repair mine: https://www.youtube.com/watch?v=aS9_t1FZ...
There is a battery compartment which is easily accessible once the controller is open. The compartment is just closed by T6 screws and the battery inside is replaceable.
Bewertung 1
5 Kommentare:
That’s perfect,
Thanks man!
von
Where would I buy a replacement battery? I’ve had bad experiences with “built-in” batteries on Xbox controllers and I much prefer using AA batteries.
von
That youtube video doesn't show anything about the battery
von
@Cincidubs its best to get the xbox rechargeable slim charge kit
von
@Cincidubs here it is elite series 2 replacement battery http://egamephone.com/index.php?rt=produ...
von
Where it sells xbox elite control 2 battery?
Bewertung 0
Antwort hinzufügen
Zhen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 20
Letzten 7 Tage: 190
Letzten 30 Tage: 802
Insgesamt: 23,410
