I’m writing this on my Mac Mini (mid 2011, Macmini5,1), which is benefitting greatly from the (MacOS-compatible) Radeon RX 580 card sitting in a Razer Core eGPU enclosure, in spite of running High Sierra 10.13.6.
This old Mac only has Thunderbolt 1, so it did require a little investigation to make work.
Here’s what I’ve ended up with:
Mac Mini Thunderbolt port > Startech 0.5m Thunderbolt 1 cable > Apple Thunderbolt 2 to 3 adaptor > Razer Core Thunderbolt 3 port.
The Radeon RX 580 has one DVI-D, one HDMI and three DisplayPort connectors. My two monitors are connected using DVI-D and DP.
Don’t be suprised if the Thunderbolt 1 cable appears expensive compared to similar-looking cables - MiniDisplayPort uses the same shape plug/connector, but doesn’t transmit the same info as Thunderbolt 1, so make sure you get Thunderbolt (note the lightning logo…).
That’s the easy bit. We are talking about an old Mac, so I had to do a bit of system-tweaking on the old Macmini5,1, specifically as per the instructions provided on the PurgeWrangler site. Bit nerve-wracking (it took a couple of goes for me!) but I’ve got a slightly more usable Mac and a bit more life out of the old dog.
Of course, Thunderbolt 1 speeds are a quarter of Thunderbolt 3, but all things are relative. Doing a benchmark with Unigine Valley, before eGPU I got a score of 152 and 3.6 FPS - after eGPU I got a score of 2001 and 47.8 FPS. I imagine most PC gamers will be utterly unconvinced, but for general browsing, video, light gaming and a bit of video/image editing, having that size of improvement in graphics processing makes, er, quite a difference. And of course, when I upgrade to a newer Mac Mini (with Thunderbolt 3, the eGPU will just plug right in and boost video performance from the get-go. And if I’m feeling really flush some time (unlikely, but…) then I’ll crack open the Razer Core (a really delightfully-designed enclosure - almost Apple-like in its simplicity and eye for detail), pull out the old RX 580 and drop in something with more grunt.
Downsides? Well, it wasn’t super-cheap, but all things are relative, and re-usability gives it a bit of extra life. The sounds the card fans make took a little getting used-to, but they’re so organic that it gives the Mac a bit of personality! The only oddity is that when I use Word (latest version) I can’t see any highlighting for when you want to cut and paste. Bit strange/irritating, but if that’s all that’s broken, I won’t complain.
Hope this helps?
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
