Zum Hauptinhalt wechseln
Reparaturinformationen und -anleitungen für die lang ersehnte Neuauflage des beliebten MacBook Air, ausgestattet mit Intels Core i5-Prozessoren, einem aktualisierten Retina-Display und zahlreichen weiteren Änderungen und Updates, veröffentlicht am 7. November 2018.
Machine not powering on - logic board issue?
The machine itself will not power on. I have tried an SMC reset, but it had no effect. I’ve tried multiple chargers in all available ports, and there is no change. I’ve disconnected the battery and attempted to power on with the charger connected, but there is no response. Attached is an image of the voltage being sent from the charger. It would seem that the machine is not drawing enough voltage to power on properly. The main question is, is this most likely a problem with the logic board? Or is it possible replacing the battery could resolve the issue? I do not have a separate battery available for testing.
Note also that there are no signs of liquid damage.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
This is likely a Board level issue (because i think the RAM, CPU, and SSD are soldered on most Macbook, Macbook Air, and Macbook Pro models.) and thus you need to unfortunately replace the Logic Board. I saw in the pictures that the Macbook is opened, was it like this before it stopped working?
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
The problem was present before removing the bottom plate. We took the bottom plate off to investigate.
von
Ok, so that means it rules out a dust-related issue because the machine was closed. Does the MacBook show anything on its primary display?
von
Most likely a board issue. Macs tend to be able to boot without a battery installed.
Bewertung 0
Antwort hinzufügen
Zach wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 1,214
