Samsung Refrigerator RS261MDRS/XAA Manual
I need a repair manual for this model as the frig side is not cooling / freezer is good. I suspect it is froze up and will need a manual to disassemble for repair.
Thanks
Ist dies eine gute Frage?
Thanks
Solution 1:
The Evaporator Coils are Frosted Over
The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Solution 2:
Evaporator Fan Motor
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
DA31-00146E - Samsung Refrigerator Freezer Evaporator Fan Motor
Solution 3:
Damper Control Assembly
The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won’t let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Samsung Refrigerator Air Damper Motor - DA31-00043E
Solution 4:
Main Control Board
The main control board might be defective. However, the control board is very rarely the cause of the problem. Before replacing the control board, first test all of the more commonly defective components. If none of these components are defective, consider replacing the main control board.
Produkt
$119.99
Produkt
$127.99
Produkt
$308.99
War diese Antwort hilfreich?
Hi @curtisray ,
Can’t find a free service manual online but here is the fast track troubleshooting manual that shows how to test the various functions so that you know what is wrong.
Hopefully a start.
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 1,251
