Zum Hauptinhalt wechseln
Das Apple iPhone 5c wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen, geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 8, 16 oder 32 GB in weiß, pink, gelb, blau und grün.
1233 Fragen Alle anzeigen
iPhone 5C unable to hear callers
I have the same issue with x2 iPhone 5Cs in my household.
They are unable to hear the person when taking a call. It works fine on speaker, also when headphones are plugged in.
Any ideas for things to try or which part to replace?
TIA
Michael
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Did all this happend after a system update? If so, something is most likely wrong with the drivers - backup your data and restore the phone.
However if that’s not the case, the earpiece speaker might be the problem. But before we dig deeper into that, here are some stuff you should try out:
  • Front facing camera
  • Ambient light sensor (just hover your finger over the top of the phone and your display should turn darker.
If these are working fine, something is most likely wrong with the earpiece speaker. Try to replace it.
However if the front facing camera and ambient light sensor didn’t work, it could be about a ribbon cable and if that’s the case, try to replace that.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
HI @lonixen and thanks for the reply.
I’m not really sure when the last system update happened, but does seem funny that its the same issue on both phones.
I’ll check the front camera and light sensor when i’m home.
I have found spare replacement earpiece speakers for next to nothing, so will swap one out if the above are ok.
If that still doesn’t work, ill report back.
Thanks,
Michael
von
Hm. It might just be a weird coincidence or something might be messed up. Unfortunately, I don't have a good answer to that. I hope that you will find a solution for your problem.
von
Antwort hinzufügen
Michael wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 78
