Why is my car not firing?
I have changed the plugs and wires and still no fire to them. What all can I check to fix this problem?
Ist dies eine gute Frage?
Check your crank sensor. It is the crank sensor that sends a signal to the PCM, this signal determines when the PCM fires the coil. So I would check crank sensor then PCM for spark. You can download the ignition part from the service manual right here good luck and I hope this will work for you.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,248
1 Kommentar
Of course the engine turns over, and there's a spark from the coil wire?
von originalmachead
