Zum Hauptinhalt wechseln
Die PlayStation 2 wird oft als "PS2" bezeichnet. Sie kam in Japan im März 2000 heraus. Reparaturen erfordern nur ganz normales Werkzeug, sind aber manchmal etwas trickreich.
junk in my trunk
How do i get all that crap out of the vent? They say to use a hand held vaccum but that never works!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 6
1 Kommentar
I like your clever title.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
You could try compressed air. If you do this, though, keep a vacuum near by because the dust will fly everywhere. I run the vacuum right next to the vent, then spray air into it. Compressed air goes in, dust comes out into the vacuum.
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
The dust that came out of mine was extremely fine, and it was everywhere inside the case. This is an exercise best done out of doors
von
I recently cleaned out an old PlayStation 2 that was purchased off of eBay. I took the brute force approach and opened the case and cleaned each component individually with paper towels and an electronics-safe cleaner. Although a tedious and nauseous operation, the device is super clean now, more so than could be accomplished with a vacuum and compressed air.
Bewertung 3
Use an old fashioned pipe cleaner (fuzzy stuff on a bendable wire). I regularly use these to clean out the crap that builds up on processor heat sinks as well.
Bewertung 2
Antwort hinzufügen
Candace wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 39
Insgesamt: 6,027
