Zum Hauptinhalt wechseln
Erschienen im Juni 2014, zu identifizieren anhand der Modellnummer B051.
Leather covering on my ear cushion is peeling off--do I replace it?
I’ve been having a slight problem lately where the leather covering the foam on the ear cushion is starting to peel out. I used to be able to wedge it back into place with my fingernail, but I think I’ll probably have to find a more permanent answer soon. Can I just glue it back into place, or is that bad for the earphones? Should I replace the whole ear pad?
Also, would the answer be different if it was just a Solo rather than Solo2? The headphones are actually Solo, but not the HD version or anything. I don’t think there’s really a huge difference between the two.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Here’s a video on how to replace them:
https://www.youtube.com/watch?v=CCzrrgwF...
Several companies make replacement pads.
Here’s cheap ones from Amazon
https://www.amazon.com/Replacement-Earpa...
Here are better ones:
https://wickedcushions.com/products/beat...
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
thanks, I'll try that out!
von
Glue near audio equipment isn’t the best idea, if you can replace it it’s probably a good idea. I’m not an expert on beats headphones and there may be better advice so I’d wait to see any more advice from others.
Hope this helps, Nick
Bewertung 1
Antwort hinzufügen
Maya N wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 32
Insgesamt: 9,836
