Zum Hauptinhalt wechseln
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Fragen Alle anzeigen
Wont turn on after reboot!
I've restarted my iPod by holding the home and power button but still wont turn on. What can i do to fix it?
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
3 Kommentare
Matt,
Can we have more information? How old is the touch? Have you tried any repairs? Did you buy from a store or is it second hand? Was it working fine before? Let us know so we can help!
von
Its second hand but was working fine before. I havent tried any repairs myself yet no. It just went black on me.
von
Does it turn on when you plug it into the wall or a computer? My first guess is that it's your battery, because it's second hand. If you dropped it or bumped it you may have managed to knock a connector loose too? If you can get into the touch I would say check your battery voltage first.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Try keeping it plugged into the computer with the sync cable and try it again, ( Home and Sleep buttons ). If it continues to not reboot, try to just restart ( while plugged in ) the normal way with the power button. If both of those don't work, you may have a bad battery.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Matt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 576
