Zum Hauptinhalt wechseln
Modell A1001 oder A1025 / 667, 800, 867 oder 1,0 GHz G4-Prozessor
Ripping sound at startup, video goes off, makes 3 Beeps
My TI book DVI 800mhz makes a ripping sound at startup, the video goes out and it makes 3 beeps. I have to zapp the PRAM about 4 times to get it to run. When it does it seems to be fine. I took it to a local store that repairs macs and was told that I need a new Logic board. I have checked the hard drive, airport card and ram and seems to be fine. What do you think?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Hi! Three beeps generally has to do with a RAM issue, so I'd try known-good RAM, and also test your memory slots one at a time by putting a module in one slot only, powering on, and then in the other slot only, powering on, and resetting the PRAM immediately before powering up each time. I'd also reset the PMU while you're at it.
One thing with Titaniums is that they use "G3 RAM", with the notch more toward the middle, instead of "G4 RAM" with the notch more toward the end, like Aluminum PowerBooks. I believe they also require PC-133 RAM, as opposed to PC-100, which can be confusing, because both types fit in the same slot, although PC-100 will not work (or I've never seen it work, anyway) in a Titanium. I've come across many Titaniums which I was told were dead, only to find that they had been tested with PC-100 RAM, and replacing it with PC-133 made them come alive again.
That said, Titaniums unfortunately are not holding up well with age, and I rarely get one that doesn't have some sort of motherboard flakiness, or at least a bad RAM slot.
Also, could the "ripping" sound be the sound of a blown speaker? Resetting the PMU should make the computer produce a solid tone, so if that tone sounds distorted or rough, that could be indication of a blown speaker. Just a thought.
Good luck, and let us know what happens!
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
PC-133, will run in slots that can use PC-66, PC-100, and PC-133, as it can be automaticly clocked down to 66Mhz or 100Mhz. PC-66, and PC-100 will not work in a bus that requires PC-133, And PC-66 Will not work in a bus that requires PC-100 Either, and so fourth. If this isn't the problem, than the Memory may be ECC (Error Correction Code) Memory, which i believe is incompatible with your computer.
von
thanks! i will check the ram out. i also have a 1ghz logic board for the Ti book also, just in case. daren
Bewertung 0
It sounds to me like the problem is the logic board.
Bewertung -1
Antwort hinzufügen
daren Smith wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 35
Insgesamt: 2,381
