Zum Hauptinhalt wechseln
Erschienen am 4. November 2017. Modell A1865, A1901. Erhältlich als GSM oder CDMA / 64 oder 256 GB / Silber oder Space Grau. (Genauso ausgesprochen wie "iPhone 10")
1200 Fragen Alle anzeigen
After replacing LCD screen. Wifi not connecting.
Keeps saying could not connect to wifi network. Before screen replacement everything worked fine. Does any one have any ideas? Everything was done right nothing was damaged. I dont understand. Any help would be much appreciated.
Or do I have to replace the wifi antenna also?
Wifi signal is very low also.
Also what is the little golden bracket for on the inside right side of screen?
Update (06/17/2020)
By the way. I can see the wifi logo and its searching its just not finding much. When it does the signal is weak and after clicking on wifi network password is entered and says could not connect. Is this a hardware or software issue do you think?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Hi Lesie, thanks for your response.
I’ve just discovered that the original flex cable must be damaged.
My first step was solder new speaker onto old flex cable. Thats what was causing the phone to get stuck in boot mode.
Then I unsoldered the new speaker, soldered it onto a new flex cable, plugged it in and bam, phone turned on everything ok. Except of course for the Face ID lol. But at least I found the problem, did even have to replace the camera, works fine. So I’m happy about that.
What i’m going to do next is take of the flood Illuminator off the original flex cable and with a heat gun replace it on the new flex cable. That should solve my face id issue. I hope hahaha.
Man what a learning kerb, the last two days feels like a crash course in everything iphone and components/electronics. And soldering at such a small area and size. But I feel like I’ve gained a world or knowlage how all the components work and what does what that’s all thanks to you guys that helped me out through this. I went into it with zero iphone knowlage or electronics knowlage.
It is my first attempt at iphone repairs never done anything like it.
Really thanks for all your help guys couldn’t of done it without you. This is a great forum to connect like minded individuals. And people like me who have never done it and ask a million questions.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Hey, is the flex cable you are talking about the wifi antenna? i have the same problem on my 6S, after lcd replacement it won’t connect to the internet. It still has the logo, but wifi and data won’t load anything. Thanks!
von
Hilfreichste Antwort
Check the connections on the motherboard. You might have knocked one loose. The wifi antenna is on the bottom of the phone. It's the silver strip/bracket looking thing. You can unscrew it and check the connection and make sure all of the ground are have a screw in them and are tight.
Bewertung 1
26 Kommentare:
Thank you so much for replying to my question Allan. I’ll check it out in the morning and let you know how it goes.
Also just for my info, I could not find anything on the net either. What would happen if one or two screws were left out? Would it have a huge impact on the phone? Or would the phone not work?
Just thought I’d ask.
Thank you
von
It depends on which screws were left out.
von
Thanks Allan. Have a good day. Ill let you know how i went
von
Hi Allan, is the bluetooth and wifi connected together, because along with the wifi the bluetooth doest work either. So i'm thinking the two issue must be connected. What are your thoughts? Or things to try to fix the bluetooth issue also.
Any help would be appreciated.
von
Yes the wifi and bluetooth antenna are the same one. It's the silver one one the bottom of the phone above the charging port. It could be a bad antenna I just changed one a couple of days.
von
21 weitere Kommentare anzeigen
Start whit only dockconnector and battery connected to logic bord and restore it on itunes when its done you can connect one component at the time to logic bord so you see where the fault is, i guess your soldering wasn’t done properly and maybe your dot projector is also defect because of water damage.
Bewertung 1
Antwort hinzufügen
Tommy Duris wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 63
Letzte 30 Tage: 291
Insgesamt: 9,607
