Zum Hauptinhalt wechseln
Das ist die Variante ausschließlich mit Wi-Fi der fünften Generation des iPad, erschienen im März 2017. Erhältlich mit 32 und 128 GB Speicher, einem 9,7" Retina Display und einem 64 Bit A9 Prozessor.
No click response from home button.
Hi.
I often find that the home button for the ipad 5 needs to be replaced because the click mechanic does not work after being transferred to a new screen. The button does not appear to be damaged and the click mechanic does work if I press on it with a spudger, however once I place the bracket in place it will not click, or only slightly. If I replace with an aftermarket, everything works and the click is solid.
Note I have repaired multiple tablets so I have some idea what I doing but I cannot figure out why this happens unless its a fault with the button.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
The problem is the thickness of the glass, the adhesive used on the home button (HB) bracket and the distance between the black dot on the HB actuator and the bracket.
I use Tesa 4695 or 61395 (red DBL sided transparent adhesive tape equivalent works too) for strong adhesion for the bracket to the digitiser glass. Replace the actuator if needed if the black circle dot is missing. Same HB should be reused due to touch ID.
Sometimes depending on if the HB feels dipped in you may need to bend the bracket closer to the home button on the middle of the bracket.
Then to finish it off use B7000 / T7000 liquid glue on the sides of the bracket and some on the sides of the HB black rubber gasket to ensure the HB stays snuggly on place.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Stuart wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 624
