Zum Hauptinhalt wechseln
iBook g4 stops on the apple logo when I power it up
why does my ibook g4 12 1.2gh stops on the apple logo when i power it up?
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
i gave my ibook g4 12 1.2gh to a friend and he jst upluged the power cable and it got off because it has no battery and when i tried to turn it on it only stopped on the apple logo with no spinning gear please help me i don't know what to do next
von
Press command control and power button at the same time
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Remove the battery and AC adapter. Press and hold the power on button for 10 seconds. Then put the battery back in and attach the AC adapter and try to start. If this fails zap the PRAM, here's how: http://support.apple.com/kb/ht1379
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
hey i have tried all that but it can't help may be you can help me coz apple support can't help me too.
von
See if it will start from your system installation disk. "C" key.
von
First, it's dangerous to use a computer without battery, cause when the AC adaptater is unplugged , the machine suddently shuts down, and this is not recommanded for computer health ( It can damage files, hard driver, or something else) . So don't do it again.
According to what you tell us , I can say that there is 2 possibles causes:
1-Your files has been damaged, so that Mac won't boot
2-Your RAM Memories can be damaged too.
Try this , and tell us more about after doing them:
1-remove the RAM memories and try each one of them separately (plug one and try , then plug the other and remove the first one and try again.
2-At Start up , press "Commande+S" to boot in single user mode and type
"/sbin/fsck -fy" exactly like this ( there is a space between "k" and the dash.
Do it until you get this message : The volume _name_appears to be OK!
and type "reboot" to restart the mac.
3-if it won't boot, you will have to reinstall it .
4-Force mac start up holding "Commande+control+powerbutton"
If all this have help you, post us back and I'll suggest you more solutions.
Bewertung -2
3 Kommentare:
i have tried all but nothing works
von
do i have to use the os disk for it to start from my system installation disk n can ubuntu work?
von
anybody who can help me here?
von
Antwort hinzufügen
rayme wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 2,686
