Zum Hauptinhalt wechseln
Anleitungen und Reparaturhilfen für Küchengeräte von KitchenAid.
20 Fragen Alle anzeigen
My motor won't turn.
I have a K45ss mixer w/ a Hobart motor. I’m fixing it up,cleaned,painted, greased and new cord. It worked before I started but now it wont’t turn . I have 120v to the speed control ,I took out the brushes out when painting and covered the holes with a foam. The brushes don’t spark or meet the standards to replace (over a half inch long) and I have tried putting them in different positions to no avail. I can turn the mixer by hand also. Any ideas ?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
To state the obvious, something happened between disassembly and reassembly. This link takes you to the Service Manual for your mixer:
++http://www.kitchenaidparts.eu/documents/...
Things to consider:
The brushes have a chamfer on one corner. This must clear a stop in the brush holder. Take a flashlight and look into the holder and make sure the brush is aligned before inserting it.
Are all the wires attached to the proper tabs on the control board?
Is the link that pushes on the control plate properly positioned. This link also actuates the on-off switch on the control board.
The Service Manual will help you make sure that everything is in its proper place.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Paul Doering wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 224
