Zum Hauptinhalt wechseln
Modell A1312 / Mitte 2010 / 3.2 GHz Core i3 oder 2.8 & 3.6 GHz Core i5 oder 2.93 GHz Core i7, ID iMac11,3
382 Fragen Alle anzeigen
Speed penalty for mounting drive in optical drive via caddy
My 2010 iMac harddrive died and I happen to have a 2.5” harddrive that I will quickly swap it out for. I need the machine running again as fast as possible. I have a caddy and am wondering whether using the optical drive/caddy method is going to be slower than if I used the dedicated SATA ports that the dead harddrive is connected too.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
If I remember correctly the SATA port the optical drive uses is only SATA II (3.0 Gb/s). The 2011 model that is true!
Frankly, I would just get this kit iMac Intel 21.5" and 27" (Late 2009-Mid 2010) SSD Upgrade Kit and just do it right! If you contact iFiit today you should be able to get express shipment and have it in your hands before the weekend. Thats when you where planing on working on your system anyways, right?
iMac Intel 21.5" and 27" (Late 2009-Mid 2010) SSD Upgrade Kit Bild
Produkt
$100.99
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
DJ Tanzil wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 42
