Zum Hauptinhalt wechseln
Das erste Smartphone von Google mit Android, das Pixel XL (Modell Nummer: G-2PW2100) kam am 20. Oktober 2016 auf den Markt. Es hat ein 5.5" AMOLED Display, 3450 mAh Akku und 32 oder wahlweise 128 GB Speicher.
70 Fragen Alle anzeigen
Phone on but screen black
Phone turns on but screen is black after I dropped it on kitchen stone floor. Good protector cover. Screen not cracked. I tried several YouTube suggestions i.e. Power+Volume up/down etc. Any suggestions? thank you.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sounds internal. The power supply for the screen may have been moved because of the fall. Unless you have some phone repair experience+the right tools, taking it to a technician should be the best solution.
If nothing is broken or needs to be replaced, repair should come cheap, too.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Wow, quick response and good suggestion. I have taken phones apart and have the tools, but have not worked on this old Pixel. Can you suggest what I need to get to repair/replace the power supply for the screen? Thanks again for your help and quick response Med_tech, appreciative.
von
If it isn't broken you should be able to just slide it back into place.
If it is, it would be a real hustle trying to find the specific spare part. In that case, a specialized tech should probably intervene.
von
You are right. I will have to find a tech to look at it. thanks!
von
Antwort hinzufügen
Mary Brady wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 399
