Zum Hauptinhalt wechseln
Zweite iPhone Generation. Modell A1241 mit 8 oder 16 GB Kapazität und schwarzer oder weißer Kunststoff-Rückseite. Die Reparatur ist leichter zu bewerkstelligen als beim iPhone 1. Es werden Schraubendreher, Hebelwerkzeuge und Saugnäpfe benötigt.
20 Fragen Alle anzeigen
Doing a repair and ripped something. Is it important?
So I’m bought an old iPhone 3 and was checking the motherboard. While i was taking off the metal protectors, one of these metal things broke (see picture)
Was wondering if they were anything important and how to fix it if it is or if I can just leave it like that
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
Picture is not clear. Looks like it is just bent. Where is it broken?
von
Added a new pic. I’m just worried because it looks soldered on and I’m not too good with soldering
von
Hi @coolmanguy124
Was the phone working or not before you opened it?
Just trying to understand why you opened it.
What were you checking on the motherrboard?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I would say that the lifting metal bracket provides more structural support for the phone and to protect the motherboard as well. In some devices its not uncommon to have a small rubber sticker on top to hide the components underneath. Take some submarine UV glue and gently apply it to the corners of the brackets.
But in future reference, never forcefully disassemble anything. If it doesn’t easily move then check for hidden screws. Never pull only gently lift.
War diese Antwort hilfreich?
Bewertung 0
You could glue it down instead of soldering as it is not a circuit. It does have to be flush otherwise the phone will not go together properly.
Bewertung 0
Antwort hinzufügen
coolmanguy124 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 116
