Zum Hauptinhalt wechseln
A guitar shaped controller for Guitar Hero III of the Guitar Hero video game franchise.
My whammy bar isn't workin
I have a ps3 les paul guitar and my dog ended up knocking it over, ever since then the whammy bar doesn’t work, it still has tension it pulls back its not flopping down or staying flat but when i try to use it, it does nothing, i need help please and thank you
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
youll want to follow this guide:
Les Paul Wireless Guitar Teardown
this will allow you to open the devoce and obtain access to the whammy bar. there youll want to inspect and see if there is any solder joint broken or loose wire due to the drop. if nothing visual is seen, it could be damaged internally and may want to consider replacing it. you can find the replacement here:
Les Paul Wireless Guitar Peripheral Whammy Bar Replacement
report back here with findings for any additional assistance if needed.
Les Paul Wireless Guitar Whammy Bar Bild
Anleitung
Schwierigkeitsgrad:
Mittel
5 minutes
Les Paul Wireless Guitar Bild
Anleitung
Schwierigkeitsgrad:
Mittel
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Will do, thank you for the reply
von
Antwort hinzufügen
Tiberius wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 35
Insgesamt: 900
