Zum Hauptinhalt wechseln
A series of inkjet printers manufactured by Epson.
Frage geschlossen
Ink Carriage will not move into CHANGE INK CARTRIDGE position
Hello. My ink carriage will not move so I can change the ink cartridges. I pressed the “Stop” button like the manual says for 6 seconds but it says “invalid operation” and doesn’t move. Thanks for helping!
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Hi @ pixieskates
What is your model of your printer?
had you tried turning off, open the printer cartridge door and On again.... and also check if there are any obstruction at the printer cartridge assembly.
Are there any ink leaks before?
von
Einen Kommentar hinzufügen
1 Antwort
Open up the lid, power it up, wait for it to do it’s back and forth thing.
When it stops, pull it genlty with your hand into desired position.
(sounds like brute-forcing it, but it worked for me, i used to have the same one)
Printers can be (and will be) the dumbest, less cooperative machines.
Treat it like it deserves ;)
War diese Antwort hilfreich?
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 4,785
