Zum Hauptinhalt wechseln
Reparaturanleitungen und Informationen zu den Nintendo Switch Joy-Con Controllern.
Joy Con still drifts just after replacement
I had a really bad up/left drift problem on my left joycon, so I ordered the repair kit and followed the guide. After replacing the stick it now has a slight downward drift problem, noticeable in calibration and while playing a game (tested game was Animal Crossing New Horizons, the character would slowly move downward when the stick was not being touched)
Ist dies eine gute Frage?
Bewertung 11
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Make sure the ribbon cable and the connector for the joystick is clean. Contaminants there can sometimes cause drift
War diese Antwort hilfreich?
Bewertung 3
As well as the 2 answers above you can also try re calibarating the joy con and lastly reset the console by holding down the power button for 10-12 seconds. Usually the 4 things mentioned here combined will sort it out. Changed about 5 sets so far and no issues now
EDIT Sorry didn’t fully read your question seems you did calibarate it already. So it could be the housing around the joystick has become dislodged. You cant also rule out that the replacement stick is just faulty. Usually in those kits you get 2 or 3 sticks so try another.
Bewertung 3
Did you try updating controllers? It worked for me
Bewertung 2
I recommend using isopropyl and q-tips but I didn't have any. I used nail polish remover and I ended up jerry-rigging a paper towel with the eye of a needle. Anyways, clean the ribbon cables, clean the connectors, ensure they are seated properly and pushed down, to ensure connected properly.
Bewertung 0
Antwort hinzufügen
Falling Rose wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 25
Letzte 30 Tage: 92
Insgesamt: 8,322
