Zum Hauptinhalt wechseln
The Toyota Highlander (also called the Toyota Kluger) is a mid-size crossover SUV manufactured by Toyota, a Japanese automaker. It features a five-door SUV body style and includes a front-engine layout with either front-wheel-drive or four-wheel-drive.
Cruise control and airbag failure after redoing my brakes
My cruise control and airbag system failed after redoing my brakes on my 2007 Highlander. Is this connected?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I can see why cruise control may not be working because some cars have wheel speed sensors and they may use those sensors for various things like reporting the speed to your speedometer and the ABS system. If you can provide us with the codes it’s giving you either by an OBD scanner or some vehicles will blink the light a certain amount of times in a given interval to tell you the code without a scanner. You can buy a cheap scanner that links to your code or take it to an autoparts store and they might scan it for free.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Laurel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 101
