Zum Hauptinhalt wechseln
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
179 Fragen Alle anzeigen
Why does my air conditioner/heater fan only work on High?
Our air/heater fan only blows air when it is set on high. It makes a hooting noise when it first starts like maybe there is something in the way. I have replaced the blower fan relay switch but that had no effect.
Update
These were all excellent. I had to replace both the resistor pack and the blower fan motor. The video on youtube was great help also.
Thank you all.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
4 Kommentare
Thank you for accepting my answer, and hope you stay cool....;-) Best of luck to you.
von
Is all this pretty standard in vehicles? I have a 2008 Ford Escape.
von
2005 kia sedona a/c i put composser /feron/climate contol/othan filter/ still cannot cool air in it.it still blow at hot. front and back
von
2005 kia sedona a/c blow out hot . blow motor work/i put new composser/ferzon/ climate contor/othan filter.front and back
von
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
+ I definitely agree with the answer from rj713 and just want to add to it. Remember though that bad resistors can be caused by blower motors with a lot of mileage on them.They build up higher resistance and that extra draw can destroy resistor. replacing the resistor may solve the problem for the short time but may re-occur. If that should happen, you may need a new blower motor. To get to the resistor, open your glove box, squeeze in both sides and let it drop down. You should now see the resistor directly behind there. It is about 3" x 1.5" with a 5/16 screw on each end and two wiring connectors. (one big one small). There is also a thermal fuse that I would replace as well since you are already there and the price for it is minor. It is a thermal fuse that goes bad often. you can fairly easy replace that one with a thermal fuse from Radio Shack or DigiKey has it as well on http://parts.digikey.com/1/parts/726775-.... So you could replace that as well, but it needs to be soldered. for your resistor repair, there is a Video that will help you with it. the part is readily available at places like this Hope this helps, and I did not mean to bump rj713's answer, but can not attach images to comments. So, my apologies.
War diese Antwort hilfreich?
Bewertung 10
9 Kommentare:
Good information there for anyone with this problem to pay attention to.
von
Agree with AB-- good info. +
von
Hello All...I have read all of the comments in this string. Very helpful BTW! However, have any of you had a problem with the car stalling at idle after replacing the resistor? I just recently replaced my resistor, but now my car periodically stalls when I'm idling at start up and/or stopped at a light, etc.. Any ideas?
von
My fan has been replace but on the inside of the car it only runs on high why
von
Did you also replace the blower motor resistor? It is a separate part from the blower.
von
4 weitere Kommentare anzeigen
I've had similar problems with my truck. You will find there is a resistor pack that divides voltage to the fan controlling fan speed. High speed bypasses the pack which is why it still works. The startup noise could very well indicate failing fan bearings--that could have caused the burnout of the resistor pack. The pack usually cost about $20 and is fairly easy to replace--look for it near the fan assembly. If you still have startup noise consider replacing the fan motor also or you will burn out the new pack eventually. Either buy a repair manual for your van or check one out from the Library and make a copy of the wiring diagram. Good luck.
Bewertung 9
1 Kommentar:
+ Good answer. They may also be able to get the wiring diagram and replacement procedures from the Autozone web site. They have a ton of vehicle specific repair guides and diagrams.
von
Sounds like the fan bearing is failing.
Bewertung 0
replace the blower and the resistor, but it still does not work any idea that can be more, fuse is good and the relay
Bewertung 0
I find this answer this information very useful. This is what happened to me also.
Bewertung 0
Antwort hinzufügen
dpace463 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 47
Insgesamt: 134,111
