Zum Hauptinhalt wechseln
Das Pixel 3a XL ist die größere Version von Googles Smartphones der dritten Generation und ist mit der gleichen Kamera wie die Flaggschiffe von Google ausgestattet. Erhältlich in Weiß (Clearly White), Schwarz (Just Black) und Purpurartig (Purple-ish), erschienen im Mai 2019.
Is the pixel 3a volume flex ribbon cable interchangeable with the 3aXL
Hi guys I accidentally purchased the wrong part for my pixel 3aXL… I bought the pixel 3a volume flex ribbon cable instead of the 3aXL. However, the flex cables look very similar…the buttons are in the exact same placement as well as the circle cut pass-through alignment points…there is a slight difference in the cut outs on the sides… but I don't think it should affect fitment. Does anyone know if these are interchangeable?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I tried to assemble the pixel 3a volume flex cable and there are a few differences...
It's not quite as wide so it actually doesn't fit into the housing as well. it's incredibly difficult to get the fit for the buttons to work right. Additionally the cable is not quite as long as either, however the buttons do you line up in the right area.
The biggest problem is that the male to female connection from the ribbon cable to the motherboard does not actually lineup and is off by about 2 mm.. if I were to make it fit I would have to make a hard bend to the ribbon cable which I'm sure would damage it.
... So in a pinch I would assume that someone would be able to make it work... but I would definitely feel more comfortable just buying the be part.
Just and FYI for everyone.
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
Yes it’s same cable for pixel 3a and 3axl
Bewertung 1
2 Kommentare:
Thank you David, you rule!
von
Unfortunately David, I tried to assemble the pixel 3a volume flex cable and there are a few differences...
Thank you tho!
von
Antwort hinzufügen
Brandon Watkins wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 501
