Zum Hauptinhalt wechseln
Modell A1502 / 2,6 GHz (Turbo Boost bis zu 3,1 GHz) oder 2,8 GHz (Turbo Boost bis zu 3,3 GHz) Dual-Core Intel Core i7 Prozessor mit 4MB geteiltem L3 Cache.
494 Fragen Alle anzeigen
Issues with iFixit support
Just got the new battery replacement for a late 2014 model a d I am having an issue with a black screen and I have done everything I can possibly think to correct the issue. Resetting the Ram, configuring the battery for optimal use. Plus a new dispute ribbon into the computer and still nothing the battery works and so does the computer. I am using an external display and the computer is completely functional except fo the built in display which won’t turn on. Also back light is not on. So any thoughts. I tried to connect with a respective at iFixit and I have to say very disappointed with the gentleman I talked with. Not helpful at all and just stated I should return the item for a refund or request a new battery.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
This question was migrated from https://www.ifixit.com/Answers.
von
This question was migrated from https://meta.ifixit.com/Answers.
von
Einen Kommentar hinzufügen
1 Antwort
Hello stantermini,
Thanks for reaching out! Sorry to hear you’re having some issues after completing a battery replacement. I can’t diagnose the issue for certain, but it sounds likely that a connector didn’t get fully reattached, which can result in a display malfunction. I’d open up the laptop and make sure all connectors are secure.
Remember that you’re still welcome to take up the offer for a refund!
I’m moving this post back to the Answers forum in case one of our community members has some insight into this issue.
I hope this helps, and best of luck with your laptop!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
stantermini wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 48
