Can you install the macOS Catalina Patcher with a hard drive
Can I install macOS Catalina patcher with a hard drive that is in a external bay or do I need a external hard drive or USB?
Ist dies eine gute Frage?
You really can’t run Catalina on this series. Its not worth the effort!
Remember this series can have limited RAM (2.26GHZ - 8 GB or 2.4 GHz - 16 GB). Also you can’t run older 16 or 32 bit apps which you likely have.
Lets say you had an i-series CPU for the sake of argument - Booting up your system, from which ever drive is controlled by using the Boot Manager by pressing the Option (⌥) key when you startup your system.
References:
War diese Antwort hilfreich?
You theoretically could run Catalina on this MacBook but I really wouldn’t advise you to. It still has a Core 2 Duo and it’s just not worth it to get Catalina on with faults when High Sierra works perfectly fine on these MacBooks.
I still use High Sierra unfortunately since that’s the maximum version my iMac supports, but chances are it’s still good for the next 5 years or so.
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 540
