Zum Hauptinhalt wechseln
Veröffentlicht am 21. September 2018. Modelle A1920, A2097, A2098, A2100. Erhältlich als GSM oder CDMA / eSIM oder dual-SIM / 64, 256 oder 512 GB / Silber, Gold oder Space Grau (Ausgesprochen "iPhone 10s S")
398 Fragen Alle anzeigen
Dropped iPhone in water, Phone died, Won't charge
So I dropped my phone in a pool last night and it worked on my way home until it died. I tried charging it last night but got the water in lightning port thing so I just thought I’d let it sit and charge it in the morning. I tried charging it this morning and it shows the little battery dead icon and when I plug it in it changes to the one without the cord on it but it will never turn on. Also there is a green strip going down the screen when it shows the battery dead icon. It is there sometimes but goes away sometimes as well. I thought the IPhone XS was water resistant so I didn’t think it was that big of a deal. It was maybe not even a foot underwater. Can I fix this or should I go to a repair store somewhere?
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
You can take it to a repair shop but it might not be worth it to fix. Once it gets wet corrosion will start immediately and it is worse if electricity is applied. You definitely shouldn't have changed it. The screen is definitely dead. Most shops won't work on water damaged phones except to retrieve data. Did you have a crack on the screen or back of the phone?
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
You can try putting it in a bag of rice for 24 hrs or so to draw out the moisture, however I think Allan may be correct.
von
Rice does nothing except get stuck in the charging port. The rice myth is just a myth it doesn't do anything.
von
Do NOT PUT IN A BAG OF RICE it does nothing for it except to get rice stuck in the charging port. If you were able to take it apart and dry it off from the inside there is a small possibility it will work but who knows for how long I wouldn't bother fixing it unless it had information you wanted off of it. Most repair shops won't even work on phones that have been wet except for data recovery.
von
@sithlord rice does nothing, why do people think rice dries out wet phones?
von
@strongbow I remember TheVerge having an article about it years ago. I seem to recall them dating the myth back to at least the 40s. This myth was all around when mobile phones came to life (way before smartphones). I had a “huge” Philips thing, back in the early 90s, and even back then people swore to the rice for moisture damaged devices.
von
use a wireless charger
Bewertung 0
Antwort hinzufügen
Filip Kates wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 44
Insgesamt: 2,146
