Zum Hauptinhalt wechseln
The first generation Neon was introduced in January 1994 and manufactured until August 1999. It was available as a four-door notchback sedan and a two-door notchback coupe.
speedometer does not work
speedometer does not work checked codes had p 0500 (vss bad ) replaced vss still not working (no codes ) replaced instrutment cluster .still not working .replaced engine computer .still not working . replaced connector to vss .still not working . any ideas ?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Have you checked the output gear on the transaxle to see if the gear is damaged or broken. It sounds like it's not spinning the sensor.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Dale Packard wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 216
