Stuck on bootloader screen
stuck on bootloader screen. when I try to re-boot it just keeps coming back to boot screen
Ist dies eine gute Frage?
Try a Hard Reset.
War diese Antwort hilfreich?
+ I like it when you talk like that. Ever thought of running for president?
Is the operating system stock Android that came with your phone?
If you installed a custom ROM, sometimes they can cause your phone to "boot loop" like that. Most of the time using a different kernel will solve the problem. That only applies if you're not using the stock operating system, though.
If you rooted the phone go into the root menu: With celll off hold down button volume tap power on while holding down. Go to recovery do a wipe cache then go to advance and do a wipe cache in your selected rooted. MOST of the time this will repair the problem.
step 1 turn off phone
step 2 count to three
step4 throw it as hard as u can at the ground
step5 pick up phone place gently in trash
step6 walk away.... lmao
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 4,386
