Zum Hauptinhalt wechseln
A1418 / EMC 3068 / 2017 / 2,3 GHz Dual-Core i5 Prozessor. Erscheinungsdatum Juni 2017.
iMac won’t turn on after upgrading RAM and SSD
I purchased 2 8GB RAM modules and 1 TB SSD to upgrade my extremely slow base model 2017 iMac. I followed the instructions meticulously, took me about 4-5 hours from start to finish and now the thing won’t turn on at all!
Where do I even start trying to troubleshoot the problem? Everything appears to be reconnected properly. I’m ripping my hair out as I need my computer for both work and school!
Update (08/06/2020)
2 led lights
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I took everything apart again to double check the RAM modules, noticed one appeared to be slightly damaged so I swapped it out with one of my old ones. Put everything back together and everything is working now.
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
Locate the onboard diagnostics along the left edge of the logic board near the fan
What are they telling you?
Bewertung 2
1 Kommentar:
2 lights come on. I can only upload a photo as an answer.
von
Antwort hinzufügen
Larissa Starr wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 389
